Fan still running???
Just got my new V force delivered today and took it for a break in ride. It is totally different then my DS, but one puzzling question. The fan kicked on and ran, but when I shut the motor down and took the key out the fan still ran. Is this normal???
Thanks!!!
Thanks!!!
If it runs continually after the motor is cool you might have a problem, otherwise it will quit running when the motor is cool enough. I rode mine for a while tonight and after i shut it off(and took the key out of the ignition) the fan still kicked on a couple of times.
They do make some additives you can put in your radiator (can't remember the names right now) they will make your ride run a little cooler and the fan won't come on as much or so i've heard. do a search on the forum and you should find out more info..
Water wetter, purple ice, 40 below, DEI radiator relief, and there is another product I cant remember off hand that was the cheapest, It was at autozone, $5.86 for a 12 ounce bottle (more than you need).
Its not hard on your battery and good for your engine. The prairies do the same thing.
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
