Samcoeds V-force was knocking them off....
#21
Stacy, now you got problems. Which one to make faster. The DS or the V-700.??????
I <u>know</u> <u>BOTH!</u>!! LOL
J Ross
J Ross
#22
JEFF you are right but i think in the long run the vforce will be faster in a drag race with work and a wheelie bar because of the auto and all the torque MIKE thanks alot i am going to try some port work by bob and some cams and see what happens i need some more top hp the torque is great now and when i spray nitrous it will go through the roof so i am working on hp insteed of torque let me know when you get them vids up thanks guys for all the good words and support.
STACY
STACY
#28
hey stacy you seem to be a genious when it comes to this stuff so i got a q for you. I only weigh 135lbs and im having problems with my 700's back shock bottoming out a lot anytime I land on flat ground so i was wondering what setting would you suggest for the rear shock for stock and also how do i check to see if the air tank for the shock is properly filled? I appreciate the help.
#29
I WOULD TIGHTEN THE spring preload some if it is bottoming out the shocks i think have nitrogen in them so i dont know how to check them. sorry[img]i/expressions/face-icon-small-sad.gif[/img]
