V Force jet kit install
Old Jul 10, 2003 | 08:31 PM
rc3's Avatar
rc3
Default V Force jet kit install
Ok, this might sound confusing, Dyno Jet #'s are smaller than stock #'s. Here is the reason the number on a stock jet has to do with the size of the whole, and the number on a Dyno Jet is the amount of fuel that can go through the jet. Dyno Jet tells you exactly what jet's to use depending on your elevation and they are spot on. We have been using Dyno Jet's in all of our bikes for a while now. We also have a V FORCE with Dyno Jet Kit and Dual Pro Circuit exhaust let me know if you need any help (it's actually my dad's bike but I will get you the answers. I also run Dyno Jet in my Raptor!
AND NO DYNOJET IS NOT THE SAME AS DIAL A JET,
Old Jul 10, 2003 | 11:57 PM
pairof98s's Avatar
I agree with the others. DynoJet uses a different jet number for the same fuel delivery as the carb mfg. Their needles are also designed with a different taper, which they claim is the most important circuit in the carb for tuning because it delivers the 1/4 to 3/4 throttle. The main jet is only for the wide open throttle.
It is hard to argue with the performance tips they recommend. They do all the research and tell you what to put in it. These are the same guys who make the dyno's that all the shops use to measure horsepower, so you know they are dyno'ing their jetting products.
Old Jul 11, 2003 | 12:50 AM
vtwiner's Avatar
I had no idea that the Dynojet #'s and stock #'s don't mean the same thing. I wish they gave me some kind of conversion chart. Does that mean that I went to a larger jet instead of a smaller jet? I'm running Dynojets #118 and #122. Thanks guys..
Old Jul 11, 2003 | 12:54 AM
wildwill's Avatar
Check out NYROCS site I think he has the conversion chart there.
Old Jul 11, 2003 | 01:41 AM
  #15
Puttnutt24's Avatar
I keep hearing mentions of this site,where can I find NYROCS site?, Putt
Old Jul 11, 2003 | 02:34 AM
  #16
vtwiner's Avatar
I dint know if this link will work, but if it doesn't just look for any thread that nyroc responds to and click on " nyrocs knowlege base"
http://atv.dnsalias.com/tipview.cgi
Old Jul 11, 2003 | 11:17 PM
  #17
rc3's Avatar
rc3
if you are running that small of jets I would be worried, My dad is running a 138 and a 142 in is V Force. And that is Dynojet #'s
Old Jul 12, 2003 | 12:22 AM
  #18
vtwiner's Avatar
From what little instructions came with the kit, Dynojet recommends running jets #118 and #122 if your riding from 3000 feet to 6000 feet. Since I ride at or above 6000 feet I could probably go even smaller because it recommends running #116 and #120 above 6000.
Old Jul 12, 2003 | 09:31 AM
  #19
cmecomecmego's Avatar
in the long run is a jet kit bad for your motor, and can you tell the difference once you put the kit on
Old Jul 12, 2003 | 12:11 PM
  #20
rc3's Avatar
rc3
My bad, ours is jetted for sea level and for aftermarket exhaust, you will know if your jetting is right by riding it!
ALSO how is the jet kit bad for the motor over time? Is it worse than just jetting your stock carb and changing your needle position in your stock carb? Thanks!!!
