camo
how good is, can it hold up to tree branches scrathing alone when im in the woods, does it peel off over time.
almost have the deal done on a p700, they only have camo and i like the way it looks, but is going to stay that way ???
On the p700, i am not postitive, but i think the camo patern is all the way through the plastic, it cannot scratch, But on the other hand, i would like to know if it is a good idea to get that camo sticker stuff to put on my quad, will it fade, scratch and just look bad?
The camo on my '03 P650 started flaking off. Kawasaki replaced the plastic. The camo is baked on the plastic, mine is green under the camo. I have not had any problems with it since. I would not use high pressure sprayers to clean it. Once it gets a small scratch that goes the camo it will start peeling worse when hit with a pressure sprayer. It seems to be pretty tough, but I think it would start peeling if you went through a lot of brush.
