Tired of popping and dying at idle.
The Prairie 650 runs fine but seems to pop alot at idle. No backfiring just popping and stuttering. At speed it is fine. I always need to choke it to start it no matter the temp. I assume I need to adjust some carb settings but unsure as to what. Any ideas?
YES, Stakk is correct. As per his recomendation to me it worked wonders @ 2.5 turns in north GA.
I will add that if your popping is durring engine breaking when the throttle is shut, your idle may be too low starving the motor for air. Bump it up a little bit.
Well I checked it out and the rear carb was at 2.75 turns out and the front was at 1.5 turns out. That was set at the store and is the way I have been running it. I changed this to 2.5 turns out front and rear. So by turning it in vs. out, which way is giving you more air? In or out? Out I would believe.
Thanks...
Thanks...
Out is richer=more fuel....In is leaner=more air, having them the way they were was probably throwing the carb sync off, stock is 2 1/4 turns out, 2 1/2 turn's out is a hair richer, should be fine there.....
Karas3434
Aug 3, 2015 09:17 AM
