toe in set at 0
Old Oct 13, 2003 | 12:48 AM
atcfan's Avatar
Default toe in set at 0
i was wondering if the toe in set at 0 reduces steering stiffness alot. my p700 steers stiff even after putting synthetic oil in the front diff. i checked out nyrocs site on this topic and looks fairly easy. any suggestions.
Old Oct 13, 2003 | 01:08 AM
nyroc's Avatar
Wide tires, ITP spaced front rims, low front tire pressure all contribute to steering stiffness. Tire pressure can be a big factor. My steering is very easy with the mudrunners I have. They are narrow, stock wheel spacing, pumped up to 5psi. I use Mobil v-twin in front diff (20w50).
What oil did you put in the front diff? I wouldn't play with the toe unless you have a handling problem.
Old Oct 13, 2003 | 01:11 AM
atcfan's Avatar
mobil 1 10w40 synthetic motorcycle oil, i have the cheap stock tires set at 5psi
