P700 rattle
Old Oct 22, 2003 | 09:36 AM
JSepp's Avatar
Default P700 rattle
I bought a new p700 and took it out for the first time. When I go really slow practically a coast I hear a rattle under it. I cant tell where its coming from. As soon as I give it gas it goes away does anyone have this problem? As I read some of these posting it sounds like I get to look forward to the blinking 2/4wd thats just great. thanks :
Old Oct 22, 2003 | 12:51 PM
trx450's Avatar
Default P700 rattle
you are gonna have to be a little more descriptive about the noise.
Old Oct 22, 2003 | 01:17 PM
kaw4life's Avatar
Default P700 rattle
I had a similiar problem at 13 hrs on my P700. It was a loose bolt on the front rack. Start by feeling different components on the bike while it is making the noise. You will soon find it. Good luck.
Old Oct 22, 2003 | 04:01 PM
JSepp's Avatar
Default P700 rattle
It sounds like its in the differential I cant ttell
Old Oct 22, 2003 | 04:11 PM
Nightryder888's Avatar
Default P700 rattle
same thing happened on mine, one of the skid plates was loose just tighten up the bolts
Old Oct 22, 2003 | 04:15 PM
LEP7MM's Avatar
Default P700 rattle
a friend of mine has a P-650 nad his display was flashing on and off. After we checked around for about 1/2 hour, we found a module that was loose under the fender on the front right side of the machine. If I remember right, there are a couple there. They're located infront of the shifter. Kind of a pain to get to, but with a couple skinned off knuckles, a little swearing, and lots of persistence, we got it back together and all was well.
firsttimerider
Sep 20, 2015 09:07 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Mikesohio
Jul 26, 2015 10:51 AM
rooster
Feb 8, 2007 07:44 PM
YamahaTodd
Aug 2, 2004 06:35 AM
