Sping question
Old Oct 26, 2003 | 11:37 PM
Doctor1's Avatar
Default Sping question
I got the epi pink and hpd plain spring's in the mail fri. I installed the pink spring yesterday it was very very easy. Basically you take the 10mm bolt's out of the cover then take the big bolt out of the center of the clutch cover (NOTE IT IS LEFT HAND THREAD) then take the 10mm bolt's out of the clutch cover and the cover and spring come off then reverse. I was being very careful and took my time doing this and it took a whole 15 minute's next time it may only take 5 min's or so it is very easy to do. I have not had a chance to ride it with the new spring to see how it is I rode it down the street in the neighbor hood but really could not get on it. It does engage at the same point the stock spring did.You could actually swap springs out on the trail's or dune's no problem only tool's needed are 10mm 1/4 ratchet/socket, 17mm 3/8 ratchet/socket, and a phillip's head screw driver.
Old Oct 27, 2003 | 10:52 AM
TechTip101's Avatar
SO you guys think the plain and the red. Where do you recommend I get them. Are they both Primary springs or ?? I got the EPI pink, but where should I get the RED/PLAIN? Thanks.
Old Oct 27, 2003 | 11:18 AM
HighLifterV700's Avatar
I have both the epi pink and hpd plain springs. The hpd has a higher stall, which works great for sand dragging. Only real race ive done with the hpd plain was against a 04 YFZ 450 with a 13:1 piston, cam, pipe, and jet kit, with no lid. We did a long grass race and I beat him for about 300ft, but he started passing me at the very end. He ended up beating me by about bike and a half. I thought I faired pretty good, because those things are suppose to be major fast. The epi spring has a little better pull than stock, but not enough for a piped V, I put it in for trail riding.
Old Oct 27, 2003 | 10:48 PM
Doctor1's Avatar
TechTip101
For the HPD spring's go to HPD.
Also the Polaris primary springs are the exact same as the Kawi spring's they are interchangeable
And yes they are PRIMARY SPRINGS.
Old Oct 27, 2003 | 11:30 PM
  #15
higgsV's Avatar
more ??????? can i use the red or plain with a stock V? what's the seat of the pants difference between the two? with the higher engagement rpms will it still be tame enough for my wife to putt around on it once in awhile? thanx for the help guys.
Old Oct 28, 2003 | 12:28 AM
  #16
Mudfoot's Avatar
Gonna be pretty agressive putting if you know what I mean. Go to Nyroc's spring chart on his web page to give you an idea of the different springs and their respective agressiveness.
Old Oct 28, 2003 | 12:59 AM
  #17
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
im glad i dont have 'SPINGS' in my bike
sorry
had to
Old Oct 28, 2003 | 10:39 AM
  #18
TechTip101's Avatar
Bing you riding on Saturday???
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
