Accessory Outlet On A V Force
Old Oct 30, 2003 | 09:53 PM
JJS37880's Avatar
Default Accessory Outlet On A V Force
Does anyone know If you can wire up an accessory outlet on the V like it is on the Prairie ? I only want power when the key is on. If so what wires would I connect to. I want to be able to use my GPS without relying on batteries. Thanks
Old Oct 31, 2003 | 09:14 AM
MentalState's Avatar
If you know how to use a test light or Multi meter it shouldnt be a problem...Just pop out the dash and look at the Harness comming off the key switch.Find the wire that lights the test light when you turn key....Bingo thats the wire you want to hook up cigar lighter to...Go to Radioshack and pick up a 5$ cigar lighter...drill hole in plastic somewhere dry as posibble....Make sure to solder and tape everything very well.If you need more help I could find out what wire you will need...Just IM this is and easy mod that you should have no problem doing....
Old Oct 31, 2003 | 05:05 PM
JJS37880's Avatar
Thanks Mentalstate, I'm gonna get the stuff this weekend.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
carid
Sep 14, 2015 03:40 PM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
