no 4x4 on 650
Old Dec 9, 2003 | 07:48 PM
moosin's Avatar
Default no 4x4 on 650
i know this is an over asked question but my buddies 650 wont go into 4 wheel drives any good suggestions would help iw wouldnt be so bad if i didnt keep having to pull him out with my 650ha ha
Old Dec 9, 2003 | 08:41 PM
Kawi650's Avatar
If the 2x4 4x4 doesn't flash it's probably a fuse or a dirty switch on the handlebar. 4x2 4x4 flash on dash it might be going in and out of 4 and you don't know it or the 4x4 accuator is toast or the speed sensor is not outputting properly.
Old Dec 10, 2003 | 06:01 PM
sicnj's Avatar
check under the cvt belt to see if the speed sensor is broke that was myu problemits a wire that goes right under the belt into the machine held in by one screw.
