red hott head pipe
find out your jet size and order the next 3 sizes larger. www.sudco.com sells jets for 3 dollars
lean well maby but when we put my friends bayou back together we started it up and the float was stuck open it basically just pumped nothing but fuel in and filled the hole cylinder with fuel and when we finnaly got it started it was making the header glo read pipin hot so whe took the carb appart and unstucked (LOL) the float. why running lean i know with aftermarkets you usually always run lean at first but isnt it safer to run lean then rich. wouldnt rich be hotter.
