Yosh or Alien for V force?
Old Jan 15, 2004 | 05:40 PM
MentalState's Avatar
Default Yosh or Alien for V force?
Any comments on the fence on which set to buy...
Old Jan 15, 2004 | 06:41 PM
sn0wrider's Avatar
ALIENNNNNNNNNNNNNNN!!!!!!, even tho yoshi has some good exhausts, the alien is sweet on a v-force
Old Jan 15, 2004 | 06:48 PM
Quadfather's Avatar
Have you considered HMF? I've heard good things about Alien, Yosh, and HMF.
Old Jan 15, 2004 | 06:53 PM
trailride's Avatar
MentalstateIm going with the Alien's on mine as soon as i get the bike to put around this pink spring i got from ya.
Old Jan 15, 2004 | 07:00 PM
TheFORCEIsWithMe's Avatar
...Aliens-you can't go wrong
Old Jan 15, 2004 | 09:46 PM
VNASTY's Avatar
I like Pro-Circuits,I have not had any problems and they sound awsome.They are the same that Kawasaki are using for stock up-grade also.The HMF and Yoshi are sweet pipes to.Its all about getting the air in and out with the most fuel you can run.A good clutch kit from Dalton are EPI would help put it to the ground.
Old Jan 16, 2004 | 10:11 AM
Thanks fo input...Trailride when you going to get Your V you have had that spring fo awhile......
Old Jan 16, 2004 | 10:14 AM
zmann's Avatar
HMF.
Old Jan 16, 2004 | 08:17 PM
brining this up again...Who is running yosh wno is running alien?Want to hear about them both and only these 2 please.......
Old Jan 16, 2004 | 08:23 PM
trailride's Avatar
mentalstateIll be getting the v in march till then all i can do is look at this pretty pink spring
