Belt light on P650
Old Jan 19, 2004 | 08:26 PM
BJones's Avatar
Default Belt light on P650
Belt light is staying on and belt is squealing. What needs to be done?
Old Jan 19, 2004 | 08:32 PM
tyzorg's Avatar
LOL>>>>>> LLLLOOOOOOOLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLAAAAAAAHHHHHHHHAAAAAAHHHHHHAAAAHHHHH LLLLLLLLLLLLLLLL00000000000000LLLLLLLLLLLLLLLLL RRRRRRRRRRRRRROOOOOOOOOOOOOFFFFFFFFFFFFFFFFLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOLLLLLLLLLLLLLLLLLLL LLLLLL
ok seriously.. *COUGH LOL! COUGH* what do u think is wrong? its obvious... LOL!!! lol.. WAH WAH WAHAHAHAHAHAH!!!! um.. cough.. any way same thing happened to my cousins car when my dad and me barrowed it... wanna know what happened? belt snapped and car wouldnt drive.. no sh*t had to walk 5 miles of interstate.. god that sucked.. we were bringing the dohnuts home too.. DAMN IT!
Old Jan 19, 2004 | 08:42 PM
BJones's Avatar
Belt is squealing,therefore I don't think it is snapped. A snapped belt should not squeal. Belt light is on, I think it needs a belt deflection adjustment. Any other advice is appreciated.
Old Jan 19, 2004 | 09:35 PM
kodiac1's Avatar
Is it still running ok? I mean is it only going about 5mph forward? If not then I believe it was the 03's that had the light come on at approx 100 hours.This is to check it out. The reset procedure is simple.As far as the squealing mine started that at about 500 miles.I went ahead and replaced the belt and shimmed it tighter this time..This is not a big deal if you are mech inclined.
Most of those came with either a 1.4 mm shim or 2 .6mm shims.Mine had the 1.4.I went ot the dealer and go 2 .6 shims,a .8 shim and a 1.0 shim. I put the new belt on and used the 1.0 shim.This thing performs better now than ever.With the 1.0 I was at 22mm deflection.For some reason Kaw set these up loose from the factory.If you go to ATVPOWER.com there is all the help you need.There is instructions on how to make a compresser for the driven pulley.Hope this helps.
02 650 camo
Old Jan 20, 2004 | 07:48 PM
BJones's Avatar
It is my buddies 650. It still runs fine, belt is just squealing. I will see what shims he has and remove one. Do I need to go thru a reset procedure to clear the belt light?
Old Jan 20, 2004 | 08:43 PM
kodiac1's Avatar
I believe you do.On an 02 you unplug the the trip switch (the rectangular box on the belt cover...two wire) then you unplug the two 4 prong connectors (black and gray) and plug them in their opposite plugs.Turn the key on for several seconds and the 4wd indicator will flash.After a few seconds it should reset.I would go into ATVPOWER.com and confirm this but I believe I am right.If it were me I would get the shims before I take it apartI would bet anything it either has the 1.4 or 2 .6mm ones.If so Try using just one of the .6mm shims.Thats what most of these guys are using and some are using none but that makes it pretty tight.
02 650 camo
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
