A quick question on 700 Prairie ...
Old Jan 22, 2004 | 12:01 AM
Sox's Avatar
Sox
Default A quick question on 700 Prairie ...
I was just wondering if any one knows if the prairies magneto can run the quad with a dead battery.
And has anyone used thier pull start ... one pull or what ?
Thanks
Greg
Old Jan 22, 2004 | 12:13 AM
Kawi650's Avatar
I don't know about the 700 but the 650 doesn't like runnig with out a battery. The engine brake speedo and the 4wd system really gets confussed with a dead battery (Lights work but weaker). I personally don't like a dead battery (LOL) because when my fan kicks in I want to be assured it's getting all the power it needs to cool my bike down. Pull start can be a one pull if you decompress it first.
Old Jan 22, 2004 | 01:05 AM
Customfabandweld's Avatar
One pull for mine, full battery, though.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 22, 2004 | 06:19 AM
therock's Avatar
Tell me about your decompress method.
Old Jan 22, 2004 | 07:55 AM
p700wheelieman's Avatar
i had a situation where with the key out the instrament panel stayed on and it killed the battery it took a couple of hearty pulls but it came to life if you touched any power acc. it would die untill it charged it self never did figure out what happen went away
Old Jan 22, 2004 | 08:49 PM
Kawi650's Avatar
Sorry.... Not to say my bike is better than yours LOL Up in canada the praires have a little round **** on the right side under the airbox. You just press it in twice and it works like a primer an starting is a heck of a lot easier.
Old Jan 22, 2004 | 08:56 PM
Raptor010101's Avatar
I have not looked to see if my p700 has one of thee ***** but is it a decompressor or a carb primer??
Old Jan 22, 2004 | 09:38 PM
Kawi650's Avatar
I believe it does both. From what I understand if you use the primer it has an automatic decompression.
Old Jan 23, 2004 | 09:43 AM
newbeatle's Avatar
It is my understanding that the decompression is automatic, it is controled by cam weights similar to what are in your clutch, once they are spinning fast enough, they move out to cover the compression release valve... I don't think the cams would be any different on the Canadian models... however the primer button would be a nice option for me, for cold weather starts...
as far as the original question, the kawi's electrical system is very sensitive... you may be able to get it to start when the motor / weather is warm, but I know from expirience, that if the voltage is at all low, it won't start in weather colder than 30* - 40* F
I still haven't done the washer / spacer trick to my pull start... it has been exposed to mud too many times, & in it's current state, is just an ornement... I've always found it easier to jump start it, rather than even try to pull start this big beast...
Old Jan 23, 2004 | 04:00 PM
therock's Avatar
I pull started mine with a good batteryin 2 pulls with full choke @ 25 degrees F. I don't know why a primer is needed with an electric fuel pump?
Yes the auto decompression is weight controlled.
black_thunder
Sep 6, 2015 04:41 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
dwhipper61
Aug 27, 2015 11:01 AM
coolguy420
Jul 28, 2015 01:54 AM
