Typical Shim on new belt
Old Feb 23, 2004 | 01:14 PM
Uinthas's Avatar
Default Typical Shim on new belt
anyone know what shim or shims work best on a new belt install for a p-360 using a 360 belt??
Old Feb 23, 2004 | 01:37 PM
eiger2's Avatar
I don't think every machine is exactly the same.(why not???) You'll have to "trial and error". Some guys like the belt tight - less wear. I'm not sure why anyone would want it loose. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 23, 2004 | 01:56 PM
OleManMoses's Avatar
At around 30 hours on a brand new machine I removed both shims and installed the black epi spring
I think if i were you I would install without any shims
Old Feb 23, 2004 | 02:25 PM
Uinthas's Avatar
my belt currently has around 3k miles on it & I recently adjusted it with no shims & it squaks horribly & even moves while at idle in H or L (time for a new belt) I wouldnt suggest anyone put in a new blet with no shim at all I did that after about 1500 miles of use & it was way to tight. I realize that all bikes are different & adjustments should be made accordingly, my dealer said stock they generally come with a 1.4mm shim so maybe I'll give 1.0 mm a shot. (still sounds kind of big)
Old Feb 23, 2004 | 04:09 PM
trx450's Avatar
There is no common shim. The belts are (supposely) adjusted/set-up to the unit when assembled at the factory. I bought all 4 shims, and keep 'em in stock. I NEVER am without the correct shim! The are about $5/ea.
Old Feb 24, 2004 | 09:49 PM
Uinthas's Avatar
Well got the new belt today, threw it on with a 1.0 mm shim & she works perfect.. My deflection is just over 3/4 of an inch, no squeling at idle & no barking on takeoff's.. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 25, 2004 | 08:31 AM
trx450's Avatar
Uinthas-- you are a lucky fellow. I do NOT have that kind of luck! Good deal!
Old Feb 25, 2004 | 09:39 AM
kodiac1's Avatar
Uinthas....thats what I did on mine too.From the factory I had one 1.4 shim.I bought them all and tried the 1.0 for starters.It was on the bottom end of spec.SAme result too....this thing takes off MUCH better than it di before.I wanted to get it right since we are headed to HAtfiled/McCoy in 3 weeks.I don't want to be caught by any other guys with manual shift Vinsons thinking they can beat me again[img]i/expressions/face-icon-small-wink.gif[/img]
02 650 Camo
Old Feb 25, 2004 | 11:14 AM
Uinthas's Avatar
That's pretty much what I figured, factory brings them in with a 1.4 shim & we all know the belt slipping problems from the factory, so I figured either one 1.0mm shim or two .6 mm shims.. Luckily my 1st try paid off [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 25, 2004 | 05:03 PM
kodiac1's Avatar
Just for the record...he only THOUGHT he could beat me ...not a chance even with a slipping belt[img]i/expressions/face-icon-small-wink.gif[/img]
