Went Riding!!!!
Old Mar 1, 2004 | 09:04 AM
turbojosh's Avatar
Default Went Riding!!!!
I went riding sunday a maysville,ky. I was heading to big rock the some guy's stopped us and told us to go with them to witches creek or something like that anyways i had a good time and met alot of new people. I got the p700 stuck a couple times. But it feels like i have a little front-end play since i put my bigger tires on and been riding HARD.. What should i check i looked at all the boots and everything looked and felt tight. Is there grease fittings on this quad i looked and didn't see any?
Old Mar 1, 2004 | 02:22 PM
eiger2's Avatar
What do you mean by "front end play?"
It was a great weekend for finally gettin out, wasn't it!!!
Old Mar 1, 2004 | 02:31 PM
turbojosh's Avatar
Like i will go over a jump and i feel a little play in the front-end in the steering. Also whenever i go across ruts or a tree at an angle. I hear squeaking from time to time at low speeds also. It has 28 hours on it.
Old Mar 1, 2004 | 02:38 PM
MnFriesen's Avatar
that still doesnt really calify what you mean by "play" do you mean like it will dart from side to side or something
Old Mar 1, 2004 | 02:58 PM
turbojosh's Avatar
It feels like it there is travel from side to side and it just doesn't feel tight in the front-end. Like play in the steering when landing from a jump or coming up on a wheelie and landing.
Old Mar 2, 2004 | 02:17 AM
eiger2's Avatar
If you are running at speed does the front end wander back and forth? Can you sit and turn the bars a little with nothing happening at the wheel end? Have you checked your tie rods to be sure they're tight? Are your lug nuts loose?
Old Mar 2, 2004 | 10:29 AM
turbojosh's Avatar
tie rods seem tight. And wheels are for tight.
Old Mar 2, 2004 | 11:10 AM
kawakasi's Avatar
Yer machine is pretty new........ but check yer A-arm bushings-bearings
Old Mar 2, 2004 | 01:06 PM
turbojosh's Avatar
thanks guys i will check that later tonight when i get off work.
Old Mar 3, 2004 | 12:54 PM
eiger2's Avatar
Jack up the front end and play around with it. You'd be surprised what you'll find when you take the stresss of the parts.
