Question!!!
It should, however the CDI is different between the "02 & "03 models... best bet would be to look up the part numbers & make sure they are the same... now that I'm thinking about it, the check belt light is different on the display also... so the wiring will be different... But that not to say that you couldn't make it work... I just won't be a direct plug in replacement...
Quadzilla Heritage
Sep 25, 2015 01:39 PM
