p650 running bad
Old Mar 23, 2004 | 08:52 PM
mudboger's Avatar
Default p650 running bad
Before I go tear into it maby I could get some ideas from some of you guys.It bogs on the low end and it backfires when I let off the throttle.It just started doing it over the winter.It runs great once it gets going can still whoop my buddies grizz.The snow is gone now so I figured it would be a good time to dust off the V and put the prairie in my shop and figure this out.I have some ideas just thought I would get a few more to cover all the bases.thanks
Old Mar 23, 2004 | 09:59 PM
Kawi650's Avatar
my bets are on the carb sliders.... Been there done that! When it bogs and stalls use the pull start to start it.
Old Mar 23, 2004 | 10:29 PM
mudboger's Avatar
It starts fine and it doesnt stall it just sputters when I jab it to 5-8mph then runs fine,then it backfires when I let off.thanks for the reply
Old Mar 23, 2004 | 10:32 PM
hammerman's Avatar
The first thing I would do is change the spark plugs.
Old Mar 23, 2004 | 10:47 PM
mudboger's Avatar
The plugs are not that old 100 mi or so but I was going to do that first.thank you for the reply
Old Mar 24, 2004 | 07:07 AM
sledheadrich's Avatar
Sounds like lean pilot jets. Possibly needles.
Old Mar 24, 2004 | 05:39 PM
ForrestGump's Avatar
mine did the same thing once.the airbox was full of dogfood(possibly by mice).also check your oil, could be a little gas mixed in from not always shutting the gas off.hope this helps.
Old Mar 24, 2004 | 06:29 PM
newbeatle's Avatar
BOGER... 1st, try draining the float bowls... read the plugs... look to see that your air filter is clean & not over oiled... make sure the gas tank vent lines are free flowing ( this just happend to MIKEYBOY )... make sure that the Dial-a-jet snorkles are OK... from reading your list of mods, I'll not bother typing out the obvious...
Old Mar 29, 2004 | 12:34 PM
mudboger's Avatar
thanks for the reply guys,sorry ive been gone since wed.Im going out there right now to tear into it. [img]i/expressions/face-icon-small-disgusted.gif[/img]
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
