Question about new DYNA CDI
Old Mar 31, 2004 | 08:30 AM
hanbone's Avatar
Default Question about new DYNA CDI
I have read alot of posts on this subject. Before I purchase, I really want to know if it will run on a bone stock P700 without having to re-jet? My P700 is currently running rich in stock form, the plugs are pretty much black. It does run good and only has 15 hours on it. I really don't want to get into re-jetting due to the warranty issues. I figured that I could just put the stock CDI back on if I have a reason to take it in for warranty work.
If anyone has put this "DYNA CDI" on a bone stock P700 or is plannig to, I would appreciate your input.
Thanks in advance
Old Mar 31, 2004 | 09:57 AM
Prairiewrench's Avatar
I have had the CDI on a stock 700 P and a stock 650P both and never had to change a thing except the position of my butt on the seat,,, had to move it way ahead for take off! LOL!!!!!
Old Mar 31, 2004 | 11:30 AM
SHOTGUN's Avatar
I would think the only things that might need to be changed would be the idle and the life insurance policy.
[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 31, 2004 | 01:18 PM
RebelDS's Avatar
IF you are running rich now, it shouldn't be a problem. If anything, some have said you might have to richen it up after adding a CDI. If you are running rich, adding a CDI will bring you closer to where you should be if those who claimed that are right.
Old Mar 31, 2004 | 02:14 PM
2Prairie700s's Avatar
I put mine on my bone stock bike yesterday and it ran great. There is without a doubt a SERIOUS power increase. I have not ever pulled a spark plug out of it, so I don't know exactly how the mixture is. I do know that it didn't have any hesitation or popping or anything like that, so the mixture must be close to right. It seems just like it was, just more powerful.
One thing did change - it now starts a whole lot easier. I used to have to hold a little throttle to it to get it to fire up, but now I just hit the button and it fires right up after a couple of revolutions. I plan on taking a look at my plugs when I get a chance. I will try to let you know what I find.
Old Mar 31, 2004 | 02:15 PM
sicnj's Avatar
do you remove the diamond g holeshot module with the new cdi
Old Mar 31, 2004 | 02:24 PM
You can leave it or remove it. Once the CDI is in the holeshot does nothing.
Old Mar 31, 2004 | 02:43 PM
sicnj's Avatar
well if i end up removing the mod i should reconnect the wires correct. Just making sure
Old Mar 31, 2004 | 04:23 PM
hanbone's Avatar
Thanks for all the info. Let me kow what your plugs look like when you pull them .
Old Mar 31, 2004 | 10:43 PM
sicnj, You don't have to hook the wire up but you can if you wish. The new CDI does not use the speed sensor wire( pink wire)
