Jetting
Old Apr 4, 2004 | 10:00 PM
hondaguy1's Avatar
Default , and i will be adding a e-series pipe, K&Jetting
I have a 2001 mojave, and i will be adding a e-series pipe, K&N filter, and a jet kit. How should i adjust the carb for this? THANX
Old Apr 4, 2004 | 11:04 PM
MojaveMoron250's Avatar
Default Jetting
you will probably have to go up a jet size, what do you have in it now, if you dont know when you go to do it throw the exhaust and air filter on it and take it for a short ride, and then look at the spark plug, if it is light colored then go up a jet size if it is brown stay where you are or if its dark go down a jet (should not be dark considering all that you are doing is adding air flow.) but take the jet out and read the number on it, you want to add a bigger number (should increase no more than 2) that should cover it.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
