jetting help???
Old May 10, 2004 | 09:37 PM
muddyprairie's Avatar
Default jetting help???
I have a p700 with HL ICM , twin air, and napa hose and Dyno jet kit. The Dyno jet kit says to use 132f 136r for under 3000ft. Then it says to use a size bigger if you are using a k&n filter. Should the front and rear carbs have a 2 size difference? What jets should i use for my situation?
Old May 10, 2004 | 11:26 PM
Bocephus01's Avatar
Most people will tell you that the dyno jets are junk, I think I read on here before that the biggest dyno jets are smaller than are factory jets, not sure though. Alot of people including myself are having good results with the 142f/145r keihin setup that have similar mods as yours. While your at it you might want to get a pipe, or do the nyroc muffler mod to your factory pipe, you have already taken care of your intake and filter, all that extra air coming in needs a way to get out.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
