Hot cams for kfx400?
Old May 18, 2004 | 02:47 AM
MURDR's Avatar
Default Hot cams for kfx400?
Does any one have hotcams on there 400, if so was there a signifcant power gain and where? I got the intake and exhaust cams and had them installed at a suzuki dealership. the only thing they did was make my quad slower. I know the cams made my quad slower becasue i went and raced my buddies kfx-700 that i usually beat and i got walked on. The cams made my quad slower. I had the lash and clearence looked at again. But i think the tech had to much pride to admit he could of made a mistake. I had the cams uninstalled and my quad was fast again.
Old May 18, 2004 | 09:00 AM
Never2High's Avatar
My son just finished his KFX 400,big bore kit,quicksilver carb, 400 ex carb boot hot cam on intake side only I will check with mech. this set up really increased the power, not sure why he used intake cam only,will let you know
Old May 20, 2004 | 02:46 AM
shoemaro's Avatar
I asked grew at cwr about cams for a kfx 400 and he said first replace the stock carb. the stock carb is way to restrictive. He said using cams with the stock carb would be like drinking a milk shake out of a coffee straw. He said edlebrock makes a carb for the kfx that fits directly into the existing carb boot, and it will flat out pull your arms off. (the carb is expensive around $480)
Old May 20, 2004 | 10:31 AM
MURDR's Avatar
So what size carb should i go to. mm wise. Also, why do the cams make breathing threw the stock carb so difficult. People have said it makes there quad faster but i had no luck. Mine was faster with out hotcams????????????? The stock carb is that restrictive?
Old May 20, 2004 | 10:34 PM
MURDR's Avatar
huh!!!!!!
Old May 21, 2004 | 05:15 PM
shoemaro's Avatar
i believe it is a 38mm, but i am not positive. the stock carb is that restrictive though, in fact i believe using the 400ex carb you get about a one horse power gain. Call greg at CWR and he can hook you up on the best mods, he mods kfx's for people he races against. he himself races a mojave that runs around the high 40's to low 50's in horsepower
Scooter's Shop
23
Oct 22, 2015 07:04 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
