degree keys
you pull your flywheel off and replace the flywheel key with an offset key---this advances (or retards) your timing depending on how the key is installed--advanced timing always gives you a little more umph up top. In laymans terms, you fire your sparkplug a little sooner. EZ install other than you gotta remove your flywheel with a special puller
