v-force guys.
I am looking for some handle bars for a V-FORCE that will leave my cables alittle room and not make them so tight. tried the renthal atv bend and all the cabels were way to tight .Does anyone have any suggestions for this.thanks
I installed the Trailtech X bars with the Billet clamp and it raised the bars quite a bit. When I would turn right, the choke would bind and kill the engine. What I had to do was bend the little "wire holder" so that it would let the cables move without binding. It is a small piece of black steel that keeps all the wires together right under the black hood. I just beat mine with a hammer until I could turn lock to lock without binding. I also cut some of the factory cable ties and used some strong tie wraps to retie them in a different spot. IF you go this route, you can get whatever handlebars you want and not worry about the cables.
Good luck.
Good luck.
I have tag 2 bars with the CR high bend they work good..you will have to drill hole for shifter and trim a little here and there but they work good and feel great...I also have the billet handle bar clamp from trailtech with speedo very nice setup IMO....
Elkaholic
Sep 6, 2015 02:44 PM
