650 belt light
Old Jul 19, 2004 | 11:01 PM
TORK's Avatar
Default 650 belt light
I unplugged the belt switch by accident, went thruogh the reset steps in the service manual and still have flashing belt light. Where did I go wrong.
Old Jul 20, 2004 | 08:06 AM
LuvDaMud's Avatar
Just above the clutch cover, hidden under the colored plastic of your bike , there is a black and a white wire harnes with about 3 to 4 wires in each. With the key off , disconnect them and interchange them both (black to white,white to black). Turn the key on for 10 seconds ,DO NOT START THE BIKE!
Then turn key off , put wires back (black-black, Whie-white) You should be cured. you simulated a belt failure by disconnecting the belt sensor with the key turned on . This procedure resets' it.
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
