Degree key finally installed.
Old Jul 30, 2004 | 10:09 PM
tuffEnuf's Avatar
Default Degree key finally installed.
Cuda did you get the 6* Key?
I called DG today to order and was told they no longer sell the 4 degree[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 31, 2004 | 10:39 AM
KISSSOFDEATH's Avatar
Personally I would use a puller made for the flywheel. Anything else and you risk breaking or bending something.
tuffenuf, did Diamond G start selling a 6 degree key or something?
Old Jul 31, 2004 | 11:18 AM
vtwinriot's Avatar
KOD
On your site you said the torque on the flywheel was 240 ft lbs. Is that correct or was that correct or a typo?
Chris
tuffEnuf's Avatar
KOD
That was what I was informed, Spokesperson said there had been very low demand for the 4* key so Diamond G discontinued the 4*and sells only the 6* for the Prairie.
Since I already have aftermarket Penland Cams installed, I'm going to give the 6* key a try with my old Holdshot module first and then the DYNA. Great Instructions and Pictures on your website.
Kawituner had said in a previous post that a harmonic balancer puller would work. I'll also talk to my local dealer today to see if They'll rent me their puller or load up my ATV and get the local shop to pull Flywheel for me once my ATV is disassembled.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Jul 31, 2004 | 08:55 PM
  #15
I fixed that page discription. Check it out now for how I did it. I meant the 240 was how much ft-lbs it took to remove the bolt. That dewalt produces 240 ft-lbs.
I thought that may happen as more guys are saying a little more degree timing is better. More than likely when I get the 765 kit installed I will need the extra rev limiter the Dyna CDI offers. That will give me a total of 9 degrees of advance timing.
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
byronman
Sep 6, 2015 06:34 PM
Sep 2, 2015 11:15 PM
