Hello
right now you have the a-arm bolt recall on most of them, and coming soon is the whole a-arm recall on some of them. You should also be aware there is a stumbling problem at low RPM caused by the wrong size needle in the front carb. It should have the same size needle as the rear carb, it is not a recall but you can get the dealer to have Kawasaki pick up the tab.
