dg5
I INSTALLED MY DG5 BUT ONLY NOTICED LITTLE DIFFERENCE FROM THE ON POSITION COMPAIRED TO THE OFF POSITION? DID i GET A BAD ONE?
WITH MY 26 MUDLITES i STILL NEED TO LIFT TO GET THE FRONT END UP( WHEELIE).
tHERE IS A SLIGHT IMPROVEMENT BUT NOT MUCH ADDING THE BLACK SPRING DID ALOT MORE THAN THE DG5 . PLEASE ADVISE
iVE CKED ALL CONNECTIONS AS WELL.
I put one on my 750 and it made a huge differance. Also I ride at 5000 ft. elavation. you should notice a big differance with the flip of the switch. The one thing that I noted when rideing mine with the switch on is the motor seem to run a lot smoother and more free.Hope this helps and good luck with yours.
