2 stroke mix in exhaust kfx 80
went to start it up today for the kids and some 2 stroke mix came out exhaust pipe
kept trying to start finally after about 6-8 ounce of fluid it quit seems to have seized up
can hear starter cliking but wont turn over drained the remaineder in exaust with the drain plug in the exaust
the atv is a 2003 model and had no problems till now don't know wat to do..?
help anyone ever had this problem?
Seems it has hydrolocked, the float is probably stuck open and the fuel was just draining into the cylinder. It built up until there is so much fuel in the cylinder it wont turn over, might want to check the carb
yes sir, I bet that is it called the dealership and he said the same but also said because it is just cliking that the relay might be bad too? what do you thing and should i just tear into the carb? thanks for replying
Alex Rodak
Sep 12, 2015 09:39 AM
Sep 10, 2015 01:56 AM
