air fuel mixture screws on BF750
Old May 31, 2005 | 11:52 AM
prairie650and700's Avatar
Default air fuel mixture screws on BF750
Where are these screws am I blind and just cannot see them on the carbs??? The prairies are really easy to find and adjust. I cannot see them on the brute??? What gives. I have a backfire issue from WOT to idle and it has a stumble on the low end. It is not the low speed miss that was taken care of. The plugs are black so it is running rich. Also does anyone know if the 6e plugs are hotter than the 7e plugs??? Thanks.
Old Jun 3, 2005 | 01:56 AM
lastcall102's Avatar
Go to Kawi's site you can find a full carb breakdown
Old Jun 3, 2005 | 01:58 AM
plus check with your stealer and find out if the vin matches up for the needle recall
Old Jun 3, 2005 | 03:56 AM
killzoneq2's Avatar
If you dont know where they are at, you probablly wont find them. Almost impossible to adjust without removing everthing. Screw the new needle!!!! You will probably gain other problems when you loose the low end miss. Get the Dyno Jet, unbelieveable throttle response with this. It solves all stock Brute carb problems and is well worth the money. Or you can keep dicking around with your dealer and loose out on riding time. They want you to keep having problems, they get paied by Kawasaki for your fixes.
cdoren
Aug 16, 2015 11:22 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
