Spec Comparisons: Outy 800 v BF750 v KQ700 v P700 v P650
Old Jun 10, 2005 | 03:51 PM
MikeyBoyesq's Avatar
Default Spec Comparisons: Outy 800 v BF750 v KQ700 v P700 v P650
FYI: I updated my last comparison sheet to include the new Bomb 800 Outy:
...................Suz KQ 700 / Kaw BF 750 / Kaw. P700 / Kaw. P650 / Bomb 800
motor size......695cc............749cc..........697cc... ......633cc…………,….800
bore X stroke..102x85...........85x66.........82x66...... ....80x63………,…?
motor design...single-banger..v-twin.........v-twin.........v-twin…………,v-twin
cam design.....DOHC.............SOHC..........SOHC.... ......SOHC…………,.SOHC
compression...10 to 1...........8.8 to 1.......9.9 to 1.......9.9 to 1………,. ?
HP................?...................51.......... .....46.6............42…………….,…..62
Torque..........?...................44.7 ft lbs.....44.3 ft lbs....38?...........,...52 ft lbs
overall length..83.5".............86.3"...........?....... .........?...................86”
overall width...47.6".............46.3"...........46.5"... ........46.1"……………..46”
overall height..48"................49.2"...........?...... ..........?...................45”
seat height.....33.9".............36.8"...........34.3" ...........33.7"……………..34.5”
ground clear....10.2".............10.6"...........7.6"... .........7.6"……………….12”
wheelbase.......50.4".............50.5"........... 51".............51"…………………51”
dry weight.......602...............604.............602 ............604………………..639
gas tank cap....4.6 gal..........5.4 gal.........4.5 gal........4.5 gal……….……6.5 gal
ft. susp...........7.1"..............6.7"............. 6.7"............6.7"…………………8”
rr. susp...........8.1"..............7.9"............. 7.2"............7.2"………………..9”
ft. br. calipers..single-piston...dual-pist......dual-pist.....dual-pist…………?
fuel system......EFI...............34mm carbs..32mm carbs..32mm carbs….46mm EFI
Min turning rad..?.................10.5’……………10.2’…………..10.2’… ………………?
Old Jun 15, 2005 | 02:27 AM
Daranello75's Avatar
the bomb is really 806cc
Old Jun 15, 2005 | 01:41 PM
yamihoo's Avatar
I've read the Bomb gas tank is 5.3 US gal, 6.5 Imperial gals (whatever the hell that is?)
Old Jun 15, 2005 | 02:10 PM
alltoys's Avatar
Yamihoo,
You have it backwards, 5.3 gallons Imperial and 6.5 US gallons. US gallons are smaller volume than Imperial.
Old Jun 16, 2005 | 09:19 AM
yamihoo's Avatar
ah, thanks
raman8tor
Sep 20, 2015 07:35 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
toonces
Aug 21, 2015 01:19 PM
