Carb jetting on 650 Prairie
Old Jun 27, 2005 | 07:16 PM
LuvDaMud's Avatar
Default Carb jetting on 650 Prairie
I had one of my carbs that was flooding ( sticky float valve ). When I took the carb appart ,I noticed the jets were of different sizes. One was a 38, the other a 42. Is that nomal to have different size jets for each carb in a V-Twin. Being a liquid cool engine , there should be no difference in temp. between the two cylinders.
Thanks in advance for your feedback.
_________________________________
P 650 red 2003
Old Jun 28, 2005 | 08:02 AM
sammydogs64's Avatar
They are actually Kehin 138 front and 142 rear, this is due to the rear cylinder running hotter and therefore leaner. The rear cylinder runs hotter due to the hot air coming off the front cylinder. What is odd is the Arctic cat 650 (same motor) has the same jet front and rear 122.
Old Jun 28, 2005 | 10:00 PM
LuvDaMud's Avatar
I noticed you have a Napa snorkle for your bike. Is this something factory made or something you rigged on. And is this only for the air box or is it also available for the clutch fan intake.
Thanks for the jetting info, makes sense.
______________________________-
P650 Red 2003
ITP C-Series cast alum. rims
26in Bear Claws
Dalton black springs
Holeshot Module
Kimpex TJD Snow Trax (with ice studs) for winter fun
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
