PRARIE 400 4X4 NOT RUNNING RITE!
Old Oct 12, 2000 | 10:58 AM
dandelion's Avatar
We have a 97 prarie 400.I have replaced the spark plug,cleaned the air filter,drained the sediment bowl on the carb.
But still it will only go 50kms.per hour tops,then it just powers out! Can anyone tell me what could be wrong?
Thanks,DANDELION.
PS.I solved the problem,i just blew a little air into the sediment drain on the bottom of the carb[don't ask me what it did but it runs like a top]
Thanks TREE FARMER for your reply
Old Oct 12, 2000 | 12:53 PM
Tree Farmer's Avatar
Not much to go on, but:
Assuming your fuel is clean and dry (no condensation in the bottom of your float bowl; add some "dri-gas" if unsure), is your slide and needle rising when you open the throttle? A bad vacuum seal in the top of the carb (slide diaphragm leak) can cause the condition you describe.
With a free flow of good fuel, spark and compression, you'd expect the thing to run better than you describe. Good luck; let us know what you find out.
Tree Farmer
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Mphillips
Jul 29, 2015 08:53 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
