NEED HELP!!!!!!!
Hello,
I just tried to ride my quad.the hose off the carb float boat is leaking gas.i took off the carb cleaned the jets and float and drain screw.it still leaks gas.i think maybe the check valve on the drain hose in bad.when i start it i have to hold open the thoutle.but when it starts up as soon as i hit the gas it wants to stall. could the check valve not be making a vacume in the carb.its 2001 lakota sport.could it be one of the jets or the vacume needle part. when i put in gear it goes about 2 feet then hesitates and stop rolling. could it be the compress in the cyclinders.any help please. it stall when i give it gas. what could be the problem????????????????????????????????
thanks
thanks
