lakota jet kit question
Old Aug 15, 2005 | 01:25 AM
tmaxx's Avatar
Default lakota jet kit question
I got the dynojet jet kit for my lakota and cant figure out which hole to drill out. The directions point to a hole right next to the hole that the needle jet goes through, but i read a post that said it wasnt that hole.
Is it???
heres what i did:
1. removed the top cover of the carb
2. took the spring off
3. took out the vacume slide
4. flipped the vac slide upside down(i see 2 holes on the bottom and another off to the side) is the hole next to the needle hole the one to drill?
thanks for any help
Old Aug 15, 2005 | 09:09 AM
holeshotz8436's Avatar
ya its the hole off to the side of the slide next to the 1 u were gonna drill, the hole is just about the same size as the drill bit
Old Aug 15, 2005 | 12:56 PM
tmaxx's Avatar
ok i feel dumb asking again but i just cant seem to get it. there are 3 holes, do i drill the middle one? i hope so cuz i already drilled it before i posted. the one i drilled though was just a little smaller than the bit. it was inside the vac slide(i mean if i stuck a piece of wire through the hole it would come out at the top of the vac slide and be inside of it.
also, in the other post they said that the instructions said it was a bottom view, but was actually a top view, is this true?
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
