i need help!!!!!!!!!!!!!!
Old Sep 4, 2005 | 12:42 PM
pigeonn888's Avatar
Default i need help!!!!!!!!!!!!!!
where is the belt reset lite for 04 700 prarie
Old Sep 4, 2005 | 01:53 PM
Doctorturbo's Avatar
GOT BOOST!
Well it won't let me link so here:
Turn ignition off.
Inspect or replace belt as neccessary (P/N 99924-1315-01). You have to take the cover off and measure the deflection.
Remove Seat.
Locate the two 4 pin connectors under seat. One is black and the other is grey.
Disconnect both connectors and reconnect them to their opposite color (black to grey, grey to black).
Turn on the ignition switch.
The belt indicator light should flash.
Turn off ignition switch (note that the hour meter is reset when the key is turned on).
Disconnect the two connectors and reconnect them to their same color (black to black, grey to grey).
Turn ignition back on and confirm that the belt light is not on.
Old Sep 5, 2005 | 05:31 AM
pigeonn888's Avatar
thanks doc ill try that happy trails
Old Sep 5, 2005 | 08:00 AM
pigeonn888's Avatar
worked like a charm thanx-happy ridin
