P700 Slight tick before warm up (Adjust Valves?)
When I start my Priarie I have a slight tick in the motor untill it warms up, then it becomes less audible...
Is it possible I need to adjust my valves?
Thanks!!!
Thanks!!!
If you have much time at all on your wheeler I would recomend checking your valves. Tight valves are one of those little power robbing gremlins that tend to sneek up on people. And if they are not kept in check over time they can burn and cost you some real money to fix. You probably already do but make sure and keep a frest filter and oil on your machine. Depending on how you ride you may need to change your oil quite abit more often than the factory recommendations say.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
bpegram84
Jul 22, 2015 08:15 AM
