kfx 400
i have an 03 kfx 400 and it starts up cold fine and idles good but after 5 mins of riding it bogs out real bad when i give it gas but it still idles, then if i stall it it won't start until it cools. the exhaust pipe turns glowing red like its being heated with a torch. any ideas ?
Does it run better with the choke on or off.If it runs better with it on it needs more fuel (jetted).The header pipe glowing red means its running lean have you added an air filter or pipe ect.If so it needs jetted or the air fuel mixture needs adjusted.
