CDI or degree key?
I have an '04 V-Force and I've been debating whether or not to install the 6* key or an aftermarket CDI. Are they accomplishing the same thing or should I go with both? My machine is stock other than a White Bros. E-Series full system and filter. I also have a O/B spring that I have to install.[img]i/expressions/face-icon-small-confused.gif[/img]
I'm not sure about on a V-Force but on my YFZ i used to have a bought a +1000 CDI and it made quite a bit of difference. The top speed was a little better and the excelleration improved. As for the Degree key i am not sure. Some cdis improve the timing curve... mace
20.00 for the key,
14.00 fo gaskets.
VS 100-up for CDI's
CDI's for the V do NOTHING. don't waste your time. and unless you can get the engine to rev over 8900 rpm and still make power the added rev limit is useless as well.
John
14.00 fo gaskets.
VS 100-up for CDI's
John
MikeyBoyesq
Aug 10, 2015 11:11 AM
