did i mess something up??
Old Apr 29, 2006 | 09:06 PM
tommyboy84's Avatar
Default did i mess something up??
I had my prairie 650 apart replaceing the rear swing arm barrings and after i put it back together i have no rear breaks, i adjusted my wing nut down as far as it can go but still not enough breaks to lock up the tiers... they were fine befor.. any thoughts?
Old Apr 30, 2006 | 10:28 AM
MIDDLEAGEDCRAZY's Avatar
Did you disconnect the break line's at all? If so you will need to bleed the break's
Old May 1, 2006 | 01:43 AM
CamoKVF700's Avatar
The only thing I can think of is maybe the outer cable cover is not sitting in it's intended location. This would make the cable inoperable as the outer sheeve is not being held securely. Check up on the handle bar too. It might have slipped out of it's holder.
Old May 1, 2006 | 05:57 PM
Hayashi's Avatar
First your P650 rear brake is a cable operated wet brake system, not hydraulically operated, so there is nothing to bleed.
Assuming that you have correct type and amount of wet brake oil in the gear case and the wet brake plates are in a good shape, the only remaining varable seems to be the freeplay adjustment which you have too much. There are 3 adjustments you need to play with. One by the left handlebar and two on the swing arm just front of the shock absorber/spring. Any one adjustment affect the other 2. Make sure you have a bout 1-2 mm freeplay by the hand brake lever and about 15-25 mm freeplay at the foot brake pedal.
ltrmc02
Aug 22, 2021 02:34 PM
salixair
Nov 3, 2015 08:25 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
