brute force secondary spring
Hey guys I need to know something from someone that knows everything.
I have a lime green primary spring, I have a stock secondary spring.......I'd love to change the secondary spring to the next stiffer spring. I"m looking for more bottom and mid-range.... and don't want to be blowing belts either....nothing tooo extreme.
Does anyone know what spring I should buy? I don't plan on buying 2 new ones I just want to add to what I have.
I also have a Moose module already installed.
NEED quick help.....my bike is in PIECES MAN!!!!!!!
i have heard alot of good things about the EPI black. Performance wise it is running about the same as stock, but many have reported that it helps belt life significantly. The next step up is the EPI almond. Either will give you good results.
