bayou 220 help please
Ok Im tired and must be overlooking something simple i hope. My bayou has good spark and seems to be getting gas but it wont fire.in the past 2 days ive had it apart down to the clutches to replace them and also replaced a bad starter..it just doesnt fire any ideas? Im so darn lost without a manual but i do have one ordered but was hoping for ideas of things to check until it comes in. Thanks tim
is it not starting with either the electric start and pull start or is it just electric start. change out the plug if it wont start with either. it may look good but plugs go bad and they will spark when you ground them to the outside of the cylinder but once under compression it will make a spark that is too weak of none at all. if that doesnt work do a compression check. now if its just the electric start not working check the fuse and make sure all the wires are hooked where they shoul be. if that checks out try to jum the starter noid with a screwdriver and see if it works . if that fixes the prob it could be the noid or the relay.
