BF750 Loud noise when stoping.
Old Aug 2, 2007 | 08:15 PM
brutejess's Avatar
Default BF750 Loud noise when stoping.
If I roll to a stop not under power right before I stop there is a loud squeeling noise from the clutch for about 3 seconds.
Thanks for the help
Old Aug 3, 2007 | 06:23 PM
MikeyBoyesq's Avatar
You might try to check your CVT belt tension...maybe it just needs to be adjusted. If you don't know how to adjust the belt, you can either guy a service manual or check the tech tips section on nyroc's site.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 3, 2007 | 06:54 PM
duffus's Avatar
mikeyboyesq is right-- it is probably somewhat tight. how many miles/hours are on your brute? how long has it been since you changed belts?
Old Aug 3, 2007 | 09:21 PM
brutejess's Avatar
05 with 900 miles stock belt.
Old Sep 13, 2007 | 10:34 PM
alan650brute's Avatar
normal if your riding hard........
Old Sep 15, 2007 | 09:56 PM
mikeames's Avatar
Could it just be your brakes squeaking...they do that now and then....
Old Sep 16, 2007 | 02:06 AM
bfb750BF's Avatar
I'd say it is your Belt. Both of my '05 & '07 do it & even my older Prairie 650's did too. I did check the Belts in all of them & everything was A'OK.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
