Oil change
Look under the engine, you will see a small tubular skidplate connected to the chassis via 4 bolts. Remove this, it makes it much easier to work under there and you dont need to worry about fitting your hands in a tiny oil change hole. Use the correct socket to remove the bolt located directly on the bottom of the engine, the oil will then drain out. Let as much of it drain out, and change the oil filter while you're at it, its located under a fin covered piece of metal held to the engine by two bolts on the right side of the engine. Intall the new filter and reinstall the drain bolt on the bottom of the engine. Then unscrew the black oil cap which is located on the right of the engine in plain sight and add a little less than 2 quarts of 10w-40 oil. Reinstall the cap and you're done.
