KFX Fan ?
Old Oct 23, 2007 | 02:54 PM
kdog's Avatar
Default KFX Fan ?
Hi all,
I rode my quad at Pismo all weekend and never saw the fan go on once? is it poss it never gets hot enough or somethin? How do I test it ? I just want to make sure before I cook the motor or somethin.Is there a way to trip the fan so I can see it actually works or not and what temp does it need to be before it goes On? let me know.
Old Oct 23, 2007 | 03:33 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default KFX Fan ?
Just leave it running with it parked. It should kick the fan on then in about 5 minutes.
Old Oct 23, 2007 | 03:36 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default KFX Fan ?
I used to have one and my fan hardly ever kicked on, only times I can think of is when it was covered in mud and I was going really slow so no air was getting to it.
Do like Scooter said and let it sit and idle for a while after it is warmed up.
Old Oct 23, 2007 | 03:45 PM
kdog's Avatar
Default KFX Fan ?
K I guess I will try that. Hope it dont hurt it waitin for it to come on if it dont come on.no mods for manually turnin it on?
Casey
Old Oct 29, 2007 | 02:01 AM
kawiking's Avatar
Default KFX Fan ?
check the fuse, down by the rad.... i had same thing happen with me, fuse !!!
Old Oct 29, 2007 | 04:55 PM
Hayashi's Avatar
Default KFX Fan ?
Fan has a thermo switch and it activates (OFF to ON) when the switch senses 205 F or higher. It stays ON until the coolant temp goes down to 196 F and then it turns OFF. The thermo switch is at left upper corner of the radiator.
Remove it stick it into boiling water with a thermometer. Measure the continuity between two wires coming out from the switch with a multimeter - no ohm reading menas the switch is open (fan OFF) and some resistace means the switch is closed (fan ON).
No guess work here.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
