06 brute overheating help!!!!!!!
Old Mar 8, 2008 | 10:33 PM
edlaw13's Avatar
Default 06 brute overheating help!!!!!!!
ok heres what I know my brute overheated
bf overheated temp light did not come on and fan didnt come on either
after a search i found the temp sending unit that screws into the thermostat housing had a broken wire i soldered the wire together and now the temp light comes on when it overheats but still no fan
i ran a battery to the fan wires and it works so its not the fan motor I have looked for the buss connector that i have heard so much about but could not find one on the 2006 brute....
im totally lost any advice??????
Old Mar 9, 2008 | 01:01 AM
06bf650i's Avatar
check the breaker under the seat. if its not sticking out, then your fan switch is bad.
Old Mar 31, 2008 | 11:02 PM
kawasakicowboy's Avatar
because the fan runs qiute a bit from alot of riding the fan fuse could be bad under the seat.i know alot of people who had to replace it, including me.buy a inline fuse at any auto store w/20ampfuse so if mud resticts it the fuse will blow and not cook yur wiring.also u can run water wetterin yur radiator w/yur antifreeze u can get that at the auto store 2 it will make yur wheeler run alot cooler,and its good all year long
Old Apr 1, 2008 | 09:06 PM
chevytrkn1's Avatar
ceramic coating my exhaust helped alot, changed coolant to amsoil antifreeze and installed a inline cooler. My fan rarely comes on
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
ylomnstr
Sep 4, 2015 05:02 PM
