kfx 400
Old Mar 25, 2008 | 02:37 PM
stang2r's Avatar
Default kfx 400
2004 kfx 400 need to know how to time it
Old Mar 26, 2008 | 12:57 AM
DrRandall's Avatar
Default kfx 400
hey man
not to be rude, but that's a pretty broad question. Do you mean like....you took the chain off and you need it timed back to stock? Or put bigger cams in it and then need to time it? or the timing is off a few degrees...??? The way you word that leaves alot of questions my friend.
I believe you have to have the correct tools that help you find TDC (top dead center) or when the piston is equal with the block deck. then you have to adjust it there.
If you have no idea how to do it...there's tons and tons of info out there on the internet, or have someone that knows how locally show you. Or better yet. just take it to a shop. It shouldn't take more than an hour (estimated) if they're not busy. Sh*t...there are tons of builders on here that could prolly help.
hopefully that helps...
Old Mar 26, 2008 | 05:50 PM
stang2r's Avatar
Default kfx 400
kfx 400 440 big bore got it in time ,
