05 750 Brute running on one cylinder.
My 05 750 Brute Force has started missing on the rear cylinder. Bike was running good and was idling when the problem started. It died and then was hard to start. Once started, it smelled real rich with fuel. I changed the plugs, pulled and cleaned the carbs, swapped the plugs front to back, etc.. It will idle on the front cylinder but won't try to hit on the rear until the rpm comes up and it pops through the exhaust.
The carb is not overflooding and the fire is strong. With the bike idling, I can R&R the rear plug wire with no engine change. The rear head pipe is also cold. Seems like maybe the timing is off. Is there anyway to put a timing light on it to check? Any Ideas?
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
