losing power!
Old Jun 9, 2008 | 08:51 PM
tph99's Avatar
Default losing power!
i forgot, when i replaced the plug the old one had the center completly gone.
Old Jun 9, 2008 | 10:46 PM
bigpig750's Avatar
Yes that is the Extreme results of a fouled plug. You may need to check the timing.
Along with the others mentioned before. Does your bike ever back fire through the carb or through the tail on start up or shut off?
May be more of a valve issue.
Old Jun 10, 2008 | 09:05 AM
tph99's Avatar
never had it back fire since i put the new plug in. it purrs great and doesn't have any hesitation it just doesn't have much power.
Old Jun 10, 2008 | 10:00 AM
bigpig750's Avatar
Well if the motor is running good. Not missing or stumbling. Then maybe its (the motor) healthy and its a clutch problem. Ever had it looked at?
I'm kinda running out of suggestions.
New questions Automatic right?
Are you loosing power on take off? Does it still take off like it always did before?
Are you just loosing top end power?
Old Jun 10, 2008 | 07:02 PM
  #15
tph99's Avatar
never had anything looked at. i changed the belt once, and that's been a couple of years ago.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
