03 kawi p360
hey guys its been a while since iv been on here but last fall i replaced the boot on the rear swing arm where the drive shaft is and had to remove the two bolts that hold the swing arm to the rest of the wheeler.... now i went out and pulled it out of the shed for the first time about 2 weeks ago and noticed that it was leaking the wet brake oil from where the to bolts connect the swing arm to the wheeler i jacked it up and tried to wiggle the swing arm back and forth every thing seems to be tight still is there seals in there that may have gotten pinched when putting it back togeather or is there some thing else that could be wrong with it
